RD-E: 1800 Square Plate
A square plane subjected to in-plane and out-of-plane static loading is a simple element test. It allows you to highlight element formulation for elastic and elasto-plastic cases. The under-integrated quadrilateral shells are compared with the fully-integrated BATOZ shells. The triangles are also studied.
![rad_ex_18_sq-plate](../../../images/solvers/rad_ex_18_sq-plate.png)
