/SENSOR/INTER
Block Format Keyword Describes the sensors used to activate or deactivate an object according to interface force.
/SENSOR/INTER/sens_ID/unit_ID
sens_title
Tdelay
int_ID DIR Fmin Fmax Tmin Fcut
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
int_ID Interface or sub-interface identification number.
(Integer)
DIR Force direction.
= blank
Activation at first force
=FN
Normal Force
=FT
Tangent Force
(Integer)
Fmin Minimum force. 3
Default = 0 (Real, maximum 20 fields)
[ N ]
Fmax Maximum force. 3
[ N ]
Tmin Minimum time duration before activation when criteria is reached.
(Real)
[ s ]
Fcut Cutoff frequency.
≠ 0
A 4-pole Butterworth filter is used.
(Real)
[Hz]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type INTER:
    A Sensor is activated when contact on interface is detected, and following force criteria is satisfied:
    • F c o n t < F min or F c o n t > F max during Tmin
    Dir defines Force direction:
    FN
    Normal Force
    TF
    Tangent Force
    Sensor is deactivated if the contact is lost
    If there is no impact during a time equal to Tdelay (Line 3), the sensor is deactivated.
    A sensor is used for one interface or sub-interface. You can use several type INTER sensors.
    clip0133
  4. To obtain a class 1000 SAE filtering, the recommended value for Fcut is 1650 Hz (1.65 ms-1). Application of the filter helps to prevent wrong activation of the force-based sensor, due to a local force peak. Another method to avoid this is to use a small value for Tmin.
