/SENSOR/VEL
Block Format Keyword Describes the sensor activated when the velocity of the chosen node reaches the prescribed limit value.
| /SENSOR/VEL/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| node_ID | Vmax | Fcut | |||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time delay. Default = 0.0 (Real) |
| node_ID | Reference node
identifier. (Integer) |
| Vmax | Max velocity.
(Real) |
| Fcut | Filtering frequency of
low pass filter for nodal velocity. (Real) |
- The sensor is activated when nodal velocity is greater than Vmax and after the time Tdelay.
