/SURF/GRBRIC/FREE
Block Format Keyword Describes the free surface selection from 3D element group. Free surface is an external surface which is not connected to any other 3D element.
/SURF/GRBRIC/FREE/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
surf_ID | Surface identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface title (Character, maximum 100 characters) |
item_ID1, item_ID2,... item_IDn | List of brick group
identifiers (Integer) |
- Free surface is external surface which is
Figure 1. - A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
