/SURF/SURF
Block Format Keyword Describes the surface selected from other surfaces.
/SURF/SURF/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
surf_ID | Surface identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface title (Character, maximum 100 characters) |
item_ID1, item_ID2,... item_IDn | List of surface identifiers 4 (Integer) |
- All nodes must belong to a shell element, a brick element or a triangular shell element.
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
- If item_ID is negative, the surface normals are inverted.
/SURF/SURF/3 Title 1. -2
Surface 3 = Surface 1 + Surface 2 (the normal of Surface 2 is inverted)
