Board Outline Match Check
Verify the board outline matches the board.
The board outline is defined in the mechanical design process and is created in IGES or DXF format. Import the board layer on a PCB layout design and compare it with the mechanical design using this feature.
- Board Outline Layer: Specify a board outline for comparison.
- Tolerance: Set the allowable tolerance value.
- Layer Existence: Verify the existence of the specified layer.
- Skip to Check Board Outline to User Selected Data: Select this option to permit different layer shapes during analysis.
