Silk Match Check
Analyze differences in the special silkscreen and the mechanical guide from DXF or IGES data.
- The matching information comes from IGES or DXF data as a board layer.
- Enter a tolerance.
- Mechanical Top: Specify a mechanical guide layer to compare with the silkscreen top.
- Mechanical Bottom: Specify a mechanical guide layer to compare with the silkscreen bottom.
- Tolerance: Enter a tolerance.
