Pad Match Check
Analyze the DFX or IGES format design to compare the pad locations with the mechanical design and the PCB layout design.
- Select Component: Select components for analysis using the All or the Check Component Group option to use a specified group.
- Top Pad Definition Layer/Bottom Pad Definition Layer: Specify the layer for analysis.
- Tolerance: Enter an allowable tolerance.
