Create Event
Create an event consisting of channels and loadcases.
- In the Project Tree, open the Fatigue SN/EN Time Workbench.
- On the workbench toolbar, click (Create event).
- In the window, pick the channel group that will be used to create an event.
Create a channel-loadcase map.
- Click Add row.
- Pick channel and structural loadcase to be mapped from the drop-down list.
- Optional: Pick a channel scale and offset.
- Optional: Apply event repeats.
- Optional: Appy channel gate range.
For SN random fatigue subcase:
- Select the random dynamic subcase from the drop-down menu.
Select the structural loadcase to define mean stress correction.
The default is None.
- Set the exposure time.
Click OK.
The events appear in the Project Tree.
- Optional:
Right-click on the Events folder and select Export events to
CSV to create a .csv file from current
fatigue events.
You can import this .csv to another project to quickly apply the same events.
