Create Sequence
Create a sequence with load cases for the fatigue analysis.
- In the Project Tree, open the Fatigue SN/EN Time Workbench.
- On the workbench toolbar, click (Create sequence).
Create a sequence.
- Click Add row.
- Pick the structural loadcase or multi-loadcase from the drop-down list.
- Optional: Assign load scale.
- Optional: Apply Sequence repeats.
- Optional: To start the sequence from 0, select the Start from zero load check box.
Click OK.
The sequence will appear in the Project Tree.
- Optional:
Right-click on the Sequences folder and select Export sequences to
CSV to create a .csv file from current
fatigue sequences.
You can import this .csv to another project to quickly apply the same sequences.
