Create Fillet/Seam Welds
Create fillet and seam weld connections between parts in your assembly.
  1. On the Connections workbench toolbar, click (Create seam weld).
  2. In the dialog, define the Section size (the length measured from the toe to the root of the weld).
  3. Define the Minimum length.
    Note: Any geometric edges found that are less than the minimum weld length will not receive a weld.
  4. Optional: Activate the Intermittent weld checkbox to specify intermittent welds.
    Note: Two parameters, weld pitch and weld segment length, are required for intermittent welds. the pitch must be greater than the segment length.
  5. Find welds using one of the following methods:
  6. Click OK.
