Create a virtual cable/rod with finite or infinite stiffness between two different
parts or between a single part and ground. Virtual cable/rod is applied on
spots.
In the Project Tree, click on the Connections branch.
On the Connections workbench, click , and then select
Cable/Rod.
In the Virtual connector dialog, use the radio buttons to select cable or rod
type.
Apply to spots. You can also create new spots by clicking Create new
spot.
If Type is set to Cable or Rod,
use the radio buttons for End1 and
End2 and select the spots for each end.
If Type is set to Grounded cable or Grounded
rod, set the radio button to End 1 and
select a spot. Switch to Ground and enter the coordinates
of the ground point.
Set the stiffness of the cable/rod. Check that the Rigid option is set to
Infinite stiffness.
Click Apply.
The virtual connector will appear in the Connections branch. If
selected, you will see vectors representing the connection in the modeling
window.
