Virtual Rivet
Connect multiple part with rivets of a given diameter.
- On the Project Tree, click on the Connections workbench
On the Connections workbench, select
> Rivet.
Use one of the following methods to create the Rivet:
Method Process Pick rivet location - Select the Stand alone rivets radio button.
- Specify Rivet diameter.
- In the modeling window, select locations on the model.
Import rivets from CSV - Select the Import rivents from CSV radio button.
- Click Import.
- Browse to the desired CSV file.
- Click Open
Click OK.
The connector will appear in the Connections branch. If selected, it will be visually represented in the modeling window.
