Altair SimSolid 2022.1 Release Notes
Highlights
- Structural Sequential Analysis
- Prestressed Modal Analysis
- Transient Thermal Analysis
- Global-Local Analysis
- Scratch Disk Space
New Features
- Structural sequential analysis
- Structural sequential analysis, wherein multiple structural analyses can be linked to each other, is now supported for structural linear and structural non-linear with separating contact. This function is not supported for structural non-linear with material and geometric non-linearity.
- Prestressed modal analysis
- Modal analyses can now be linked to any structural analysis to perform prestressed modal analysis. The linked structural analysis can be linear or non-linear. All boundary conditions from the structural analysis can be used to perform prestressed modal including, but not limited to, inertial loads and thermal loads.
- Transient thermal analysis
- Transient thermal analysis based on the modal superposition method is now supported. In this analysis, the thermal response of a structure is calculated with time-dependent loads. All thermal boundary conditions are supported including temperature, heat flux, volume heat, and convection.
- Global-local analysis
- You can now perform detailed analysis on a portion of the assembly by linking to an analysis performed at the full-assembly level. Forces at all the connections can be propagated between the global and the local assemblies to take into consideration the global behavior.
- Scratch disk space
- You can now use scratch files to run an analysis. To enable this function, use click and select the Use scratch files check box. Scratch files are written to a user-defined location, with the default location being the Temp directory.
- Solver Manager
- The Solver Manager allows you to pick specific analyses and design studies in the project to solve. You can access this feature on the Design study or Project workbench.
- Release highlights
- Release highlights are now available under the What’s New section as a new window within SimSolid. This is shown on invocation of the product; you can disable it by selecting Do not show this window on startup at the bottom of the window.
- Create sub-assemblies
- You can create new sub-assemblies in the Project Tree and regroup parts under newly created sub-assemblies. Move parts and sub-assemblies by dragging and moving to the required location.
- SimSolid Connect
- SimSolid Connect is now available under Inspire’s Extension Manager. With this extension, you can transfer the geometry between Inspire and a new/existing session of SimSolid seamlessly without using geometry files. SimSolid Connect is automatically populated under the Extension Manager once SimSolid is installed. This feature requires Inspire version 2022.1 or newer.
Enhancements
- Graphical performance
- Graphical performance of large models with more than one hundred thousand facets is improved. For large models, rotating/panning the models automatically changes the parts into wire frame mode to improve the performance. The connections are also much lighter to select and delete.
- Pick info
- Pick info has been improved:
- All options are now shown for material non-linear analysis to differentiate results between fully elastic, elasto-plastic, and unloading options.
- A Pick load option is now supported for imported forced and imported spot forces in both structural and multi-loadcases.
- Deformation scale
- Deformation scale has been improved to include user-editable scale factor. To change the default, clear the default option and enter the desired scale factor. A scale factor of 1.0 indicates true deformation.
- Batch mode
- Batch mode now supports importing spot displacements from a CSV file into multi-loadcase.
- Thermal analysis for orthotropic materials
- Steady-state thermal analysis is supported for orthotropic materials.
- Connections mapping
- Virtual connections are now mapped based on tolerances from the baseline design study to a new design study.
- PSD Units
- Units have been added to the PSD function for all the boundary conditions except rotational inertia under random analysis. Create new time/frequency/PSD function is now supported under all the boundary conditions for dynamic analysis.
- SimSolid Installer
- SimSolid executables are now created using InstallAnywhere.
Known Issues
- Occasionally, part names for Parasolid files are not imported.
- Issues with linear guide rail under virtual connectors.
Resolved Issues
- Issues with periodic function definition using standard functions under dynamic analysis.
- Reaction forces of spot welds on self-connected parts.
- Seam weld creation has been improved.
- Solution has been improved for models with non-linear materials. The results now match between elastic solution with non-linear analysis and linear analysis.
- Volumetric expansion/shrinkage is now disabled when orthotropic materials are defined.
- Improved behavior of Pick info dialogue when switching between different types of analysis.
- Issues with changing units for various material properties, boundary conditions and result plots.
- Several crashes have been resolved.
- Issues with seam weld reactions plot.
- Typo in fatigue strength coefficient.
- Graphical issues with spot welds.
- Improved performance when large numbers of faces are added to a boundary condition.
- Improved error messages when materials are imported from a CSV file.
- Issues related to material database with Chinese UI.
- Issues with fitting the plot to the window.
- Stresses have been improved around seam welds.
- Issues related to fatigue properties reverting to the defaults.
- Timeout has been increased for plug-ins.
- Issues retaining custom contact conditions for thermal analysis.
- Issues with seam weld life contour and associated legend.
- Issues retaining linked analysis for fatigue load cases for subsequent design studies.
- Issues unsuppressing parts in copied design studies.
- Refresh issues in several windows.
- Improved error messages with numerical instabilities.
- Issues mapping loads from baseline design study.
- SimSolid 2021.1 has issues related to inconsistent results when copying force/displacement; these issues are fixed in 2022.1. This version also invalidates those copied force boundary conditions created in version 2021.
- Boundary conditions display related to bearing loads in multi-loadcases.
- Issues related to converting the bushing stiffness when the units system is changed.
