SS-V: 4030 Coupled Thermal-Structural Analysis - Constrained Straight Bar Under Linear Temperature Field
Test No. VTL04 Determine stresses at the top and bottom of a constrained straight bar under linear temperature field.
Definition
A straight 1 x 1 x 10 mm bar (Figure 1) is constrained at ends and is thermally loaded. A uniform temperature of 100 degress Celsius is applied to the top of the bar, and a uniform temperature of -100 degrees Celsius is applied to the bottom of the bar. The rest of the bar surfaces are insulated.
- Properties
- Value
- Modulus of Elasticity
- 2.1e+11 pa
- Poisson's Ratio
- 0.3
- Coefficient of thermal expansion
- 1.2e-5 m/m-C
- Thermal conductivity
- 43 W/m-K
Results
Ref Solution * | SimSolid | % Difference | |
Stress at the top/bottom of the bar (compression/tension) [pa] | 2.520E+08 | 2.516E+08 | -0.17% |
* Ref Solution is a 1D model
