Mesh Formats for Import
View the supported mesh formats for import.
CADFEKO imports most of the mesh formats1 by running PREFEKO and importing the resulting .fek file. Since these formats do not support specifying dielectric media, all segments, triangles and polygonal plates are imported as PEC structures in free space. Tetrahedra obtain the medium Unknown.
When importing .fek files, only the mesh parts (wire segments, triangles, polygonal plates and tetrahedra) are imported. Information regarding the solution configuration is completely ignored. Medium information and segment radii are retained during import.
The following mesh formats are supported for import:
Formats File Format
Feko model .fek
CADFEKO mesh .cfm
Feko HyperMesh .fhm
Femap neutral .neu
NASTRAN .nas
AutoCAD .dxf
STL .stl
PATRAN .pat
ANSYS .cdb
CONCEPT .dat
ABAQUS .inp
ASCII
GiD .msh
NEC data .nec
I-DEAS universal format .unv
Voxel .raw, .txt
Femap Neutral Mesh
Boundary surfaces, bordered with line curves, are imported as polygonal plates.
AutoCAD
Only LINE and POLYLINE structures, which define segments and triangles, are supported.
GiD
Hexahedral elements are ignored.
.fek
1
Except for file, .raw file and .txt file imports
