Create a cuboid.
On the Construct tab, in the Create solid group, click the
Cuboid icon.Tip: Press C,1 to use the shortcut key.
Method 1: Base corner, width, depth, height
Base corner (C) |
One corner of the cuboid. |
| Width (W) |
The cuboid dimension in the U axis direction. |
| Depth (D) |
The cuboid dimension in the V axis direction. |
| Height (H) |
The cuboid dimension in the N axis direction. |
Method 2: Base centre, width, depth, height
Base centre (C) |
The base centre of the cuboid. |
| Width (W) |
| Depth (D) |
| Height (H) |
