Create a cylinder.
On the Construct tab, in the Create solid group, click the
Cylinder icon.Tip: Press C,4 to use the shortcut key.
Method 1: Base centre, radius, height
Base centre (B) |
The centre of the cylinder base. |
Radius (R) |
Cylinder radius (parallel to the UV plane). |
Height (H) |
Cylinder height in the N direction measured from
B. |
Method 2: Base centre, top centre, radius
Base centre (B) |
Top centre (T) |
The centre of the cylinder top. |
Radius (R) |
The cylinder radius (perpendicular to the line from B
to T). |
