Focus Processing Options
Specify what operation should be performed on the selected goal.
The following processing steps are common to all goals.
No processing
Where the focus is non-complex, no processing steps are required. In order to consider the focus directly, the No processing option is provided.
(1) x  x
Real/Imaginary/Magnitude/Phase
Selects a specific component of a complex focus type. For an array, the complex component of each array element is taken, delivering a non-complex array.
(2) xRe( x ) ; xIm( x ) ; xPhase( x ) ; xMag( x )
Unwrap
Unwraps a phase component. For a phase array, the whole array is considered in the unwrap process. This operator is applied directly after selecting Phase.
(3) xunwrap( x )
Absolute value
Takes the absolute value. For an array, the absolute value of each element is taken.
(4) x  | x |
Average/Minimum/Maximum
Finds the average, minimum or maximum value of an array. This has no effect on a single value.
(5) xave( x ) ; xmin( x ) ; xmax( x )
Normalise
Normalises to the largest value in an array. For a single value, “1” will be returned.
(6) x   x max( x )
Log
Takes the base-10 logarithm. For an array, the base-10 logarithm of each element of the array is taken. This operator is only available for non-complex values or arrays.
(7) x log 10 ( x )
Offset
Adds a specified non-complex value. For an array, the value is added to each element of the array. This operator is only available for non-complex values or arrays.
(8) xx+n
Scale
Multiplies by a specified scale factor. For an array, each element of the array is multiplied by the scaling factor.
(9) xnx
Exponent
Applies an exponent. For an array of values, the exponent of each value in the array is taken.
(10) x   x n
Undefined
When a processing step is modified and the step becomes invalid, the processing step reverts to an Undefined state. Delete or redefine all Undefined steps before applying the changes to the goal.
