Creating a New 3D view
Create a new 3D view to verify the model and visualise the results.
On the Home tab, in the
Create new display group, click the
3D view icon.
From the drop-down list select one of the following:
- To select a configuration to add to a new 3D view, select a configuration from the list.
- To create a new empty view, select 3D view.
Figure 1. The drop-down list when a new 3D view is requested.Tip: You can create multiple 3D views where each view has different settings.
