Link regions and components: coil conductor
To link the regions of the coil conductor type (of the FE domain) to the components of the stranded coil conductor type (of the electric circuit), follow the next procedure:
| Step | Action |
| 1 |
                         In the Physics menu:
| → | Division of graphic zone in two and visualization of FE domain in one
                           zone and the electric circuit in the other Display of the face regions of coil conductor type in the form of array  |
| 2 |
                         In the array*, fill out the zones for each region:
Array of coil conductors
The array corresponding to the regions of the coil conductor type (2D) is presented in the figure below.
In this array, the zones which allow the visualization of the regions (of coil conductor type) and of the electric components (of stranded coil conductor type) are showed in the figure below.
