Dialog boxes: Specialized dialog box
How are the data?
The interaction with the database is done using specific dialog boxes: specialized box, data array.
This paragraph presents an example of specialized box.
Specialized box
In this box the user can enter/check/modify information relating to the data.
A specialized box is presented in the figure below.
The required fields (necessary and sufficient for the definition of the entity) are marked by an asterisk *.
General tools
The general tools available to carry out the data entry are presented in the table below.
Button Function
allow the direct access to the non-filled required fields
OK validate information and close the dialog box
Apply validate information without closing the dialog box
Cancel close the dialog box
access to the online help concerning the entity
Specific tools
The user can create a missing entity using the button in a specialized box.
