Cut of magnetic circuit: automatic creation
Operating mode
The operating mode for the user is given in the table below.
| Step | Action |
| 0 | Initial state: the domain is meshed and the physic is defined |
| 1 | In the menu Physic click on Check physics |
| → | Message of information |
| 2 |
| 3 |
                         Creation of the necessary cuts (the possible manual cuts created beforehand are taken into consideration) Message indicating the number of existing holes and the number of created cuts  |
Operation
The operation of the automatic creation command (point of view software) is given in the table below.
| Stage | Description |
| 1 |
                         Search for the holes at the level of the groups of volume regions of the type :
| 2 |
                         For each hole, search for a face that can become the support of the cut.
| 3 | For each hole, search for facets (on the volume elements) which can become the support of the cut, a cut of the type cut on the mesh is created |
