Describing sources
Introduction
We distinguish two types of sources:
- an imposed electric charge density (q0)
 - an imposed electric potential (V0)
The describing of these two types of sources in Flux software is detailed in the following blocks.
Imposed electric charge density
It is possible to impose a density of electric charge (q0) on a region by:
- using the material regions of dielectric type (as presented previously): the volume density of electric charge of sources is then one of the data entered during the definition of the dielectric region
using the regions known as non-material of the type:
imposed density of electric charge
Expression of the electric charge density
The electric charge density of sources represents the q term in the solved equation of electrostatic applications (see § Electro Static: solved equations).
The expression of this density depends on the used type of region. Information by the region type is gathered in the table below.
| For a region… | the density of the charges is a… | ||
| material |
                         massive thin (withthickness) filiform (with cross-section)  |
                         volume density (or the total electric charge)  |
                     uniform or space dependent |
| non-material | face (3D) | surface density | |
| line | line density | ||
Imposed electric potential
It is possible to impose an electric potential (V0) on a region by:
- using the material regions of perfect conductor type (as presented previously): the electric potential is then one of the data entered during the definition of the region
using the regions known as non-material of the type: imposed electric potential
Expression of the electric potential
The expression of the electric potential depends on the used type of region.
| For a region… | the electric potential is… |
| perfect conductor | uniform |
| imposed potential | uniform or space dependent |
