Export of the nodes coordinates
Introduction
In the exchange of data between finite element applications of different nature – thermal, magnetic, electric… of a given device, it is possible to have different meshing.
In order to get the chart of nodes homogeneous between the different studied applications, the user has the possibility to export the nodes coordinates starting from a support of the volume or surface region type.
Export format
Nodes coordinates are exported to a file which available formats are:
Format Description
*.DEX
DEX = Data EXchange
format specific to Flux
*.IP IP is a format for the Fluent software
PyFlux output
Export of nodes coordinates
To export the nodes coordinates starting from a support:
Step Action
1
In the menu Parameter/Quantity:
  • point on Export nodes of regions
  • activate the command Export coordinates of regions nodes
A dialog box « Export coordinates of regions nodes » is opened
2
Choose the support for the exportation:
  • choose the type of region (volume or surface)
  • choose the region
3
Specify the file to export:
  • choose the format (DEX, IP)
  • choose the file
4 Choose the position of the mechanical set (if any)
5 Validate by OK
