Simplified projective method dedicated to rotating machines
Introduction
This chapter discusses the use of the Simplified projective method dedicated to rotating machines to create force collections in the Import / Export data context : this kind of collection allows to compute forces on a mesh in order to export them towards OptiStruct to setup a NVH analysis of an electrical machine.
The following topics are covered in this page:
- Description of the approach
 - Creation of this force collection
 - Limitations
 - Example
Figure 1. Permanent magnet synchronous machine with two data supports: (a) the OptiStruct-imported support to collect the data and (b) the virtual cylinder.
Creation of this collection
- In the data tree, select the menu Forces data collection
 - In the dedicated GUI for Forces data collection, select Simplified projective method dedicated to rotating machines
 - In the Definition tab:
- Fill a value for the radius of the virtual support or let it in the automatic mode
 - Choose a data support to collect the data
 - In the Advanced tab, (those fields are already filled with default
                            values)
- Fill the Minimum number of computation points along the perimeter which must be an integer. Its default value is 1080 points.
 - Fill the Maximum projection distance (0 for optimal value). Its default value is 0 (optimal value).
 - Choose the collection interval:
- Collect for all the steps of the scenario
 - Collect only for the current step
 - Collect for a specified interval
 - Click OK
 - Right click on the forces data collection just created in the data tree and run the command Collect data
Limitations
- The support to collect the data must be cylindrical and centered on (0,0) in the XY plane, even for 3D and Skew applications.
 - The axial forces (i.e. along the cylinder axis) are equal to 0.
 - The virtual support and the support to collect the data must be in the same mechanical set.
 - The radius chosen for the virtual data support must not be stuck to the rotor or to the stator part and must be in an air or vacuum region.
In this example, the aim is to compute the global force on each tooth of the electrical machine described in Figure 1 after solving a scenario in Flux.
To this aim, a support to collect the data is imported from OptiStruct which is the same as part (a) of Figure 1; on this support, forces are computed with the Simplified projective method dedicated to rotating machines described before.
The radius automatically computed by Flux is located between the sliding cylinder (which corresponds to the line between the different mechanical sets) and the stator region as shown in the figure below:
Figure 2. Definition of the radius for the virtual support: in red the sliding cylinder, in black the virtual cylinder to compute the magnetic pressures.
Figure 3. Visualization of global forces per tooth for a permanent magnet synchronous machine: (a) the forces normal to the collect support, (b) the forces tangential to the collect support.
