Switch and Diode: definition (structure)
Definition
A switch and diode components are defined by:
  • a name (and a comment)
  • a model
  • specific characteristics depending on the model
  • a command
  • two terminals
Name
The name permitting the identification of the component is given by the user when this is created by him.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
Switch and Diode: description
Characteristic quantities, necessary for the description of the switch and diode components are presented in the table below.
Components considered Proposed models and their characteristics
Switch
Diode
Roff : blocked resistance
Ron : resistance in conduction
Diode
Exponential functions
Is : saturation current
Rs : series resistance
Ut : voltage of the temperature
Rb : extrinsic resistance
VF0 : bend tension
Note: * Only for 2D applications now
Associated command signals
The switch need a signal to command them. The table below presents the different possibilities of commands.
Proposed commands and their characteristics
At start
By formula
By square signal
Pulse start
End of pulse
Period of signal
