User sub routines (Groovy): How using paramSpatialCurrent[k,v]?
Example Create a new 2D magneto static project. This is a plan project, with a depth of domain of 50 mm.
1
2
Define:
Creates a spatial quantity, a 3D vector:
  • Name it “ VECTOR_MUR ”,
  • Component values are
x = 5000,
y = 5,
z = 0.
Create a linear magnet “ MAGNET ” described by the Br module:
  • Remanent flux density (T) = 1.6
  • Relative permeability = 1.01
Create an user material “ MAT_1 ”:
  • Select “ User magnetic properties
  • In the tab “Spatial quantity”, select “ VECTOR_MUR
3
Attribute the material to the faces region
Attribute the region to the face…
Create face region “ MAGNET ”, “ AIR ” and “ STEEL
Assign the material “ MAT_1 ” to the “ STEEL ” region …
Assign the material “ MAGNET ” to the “ MAGNET ” region …
For the magnet region, give a magnetic direction (following axis x…)
Assign faces region to faces…
and so on….
4
Click on the “ Edit user function ” to see and modify into the python editor the groovy sub routine “MaterialLaw.groovy”.
These files are in the directory: “....YOUR_FLUX_PROJECT.FLU\persistent\groovy
5
Type the following groovy (step 8) code in the sub routine public void compute (){} :
User parameter is paramSpatialCurrent“Vector_mur”. This is a double value type. The first component starts with the 0 pointer.
Note: In the key “Vector_mur” the first letter is writing with an upper case and the following, in lower case.
6
7 Solve the project
8
x= 5000,
y = 5,
z = 0.
9
Delete the previous results and modify the Vector_mur components:
x = 5,
y = 5000,
z = 0
solve again the flux project:
10
