Geometry dimensional checking: compute
Compute the distance between two points
To compute the distance between two points in a local coordinate system:
Step Action
1
Activate the command:
  • in the Geometry menu place the pointer on Measure and click on Compute distance between points
A dialog box Compute … is open.
2
Fill out the fields:
  • select first and second points (selection of several points is possible)
  • choose a coordinate system
3
Validate the information:
  • click on OK button
The computation result appears in the output zone.
A dialog box Compute … is automatically opened.
4
Quit the sequence:
  • click on Cancel button
Compute the coordinates of points
To compute the coordinates of points in the global coordinate system and in a local coordinate system:
Step Action
1
  • in the Geometry menu place the pointer on Measure and click on Compute coordinates of points in a coordinate system
2
  • select the points in graphic zone or enter the numbers of points (selection of several points is possible)
3
4
Quit the sequence:
Compute lengths of lines / areas of faces
To compute lengths of lines / areas of faces:
Step Action
1
  • in the Geometry menu place the pointer on Measure and click on Compute length of lines / Compute area of faces
2
  • select lines/faces (selection of several lines/faces is possible)
3
4
Quit the sequence:
Compute a bounding box dimensions
To compute a bounding box:
Step Action
1
  • in the Geometry menu place the pointer on Measure and click on Compute bounding box
The computation result appears in the output zone as follows:
  • dimensions [X1,X2][Y1,Y2][Z1,Z2]
  • center (x,y,z)
