AbaqusODB Upgrade
AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2016 (or earlier) to Abaqus 2021.
Since the HyperView Abaqus ODB reader supports only Abaqus 2017 files, you must upgrade files from older versions.
If you have Abaqus 2021 installed, you can also use the upgrade command in Abaqus to perform upgrades.
                Launch AbaqusODB Upgrade on Windows.
                Launch AbaqusODB Upgrade on Linux.
