Register HVPcontrol
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
                Start Register HVPcontrol in Windows.
                        From the Start menu, select All Programs.
                        On Windows 10, go to the All Apps menu.
- Select Altair <version>.
                        Select Tools > Register HVPcontrol.
                        On Windows 10, select Register HVPcontrol<version>.
 A message is displayed stating that the registration was successful.
                Manually switch to a previous or newer version of HVP ActiveX control.
                        Using your file browser, locate HVPControl.dll,
                            which is usually found at
                                C:\Altair\<version>\hw\bin\win64
                        Windows has a program called regsvr32 that is used to register controls. The HVP control is a 32-bit library so you would use the same regsvr32 program to register on a win64 machine.
                        Go to Start > Run and enter regsvr32 followed by the
                            path and name of the control you want to register.
                        Place the path in quotations. For example, to register the HVPControl.dll enter:regsvr32 "C:\ Altair\<version>\hw\bin\win64\HVPControl.dll"
                        Click OK.
- Click OK.
                        To view a list of options for the regsvr32 program enter only
                                regsvr32 in the run box and click
                                    OK.
                        A list of options is displayed.
