Import Files
Import an existing file to the current session.
Importing any type of file into HyperWorks CFD essentially means that the selected file is appended to any file currently open. It does not overwrite/replace the existing file. Therefore, you can use the Import option to open two (or more) files into one window.
If the current model is a discrete FE model and you try to import a CAD b-spline model, the imported model will be converted to a discrete FE model during import.
If the current model is a CAD b-spline model and you try to import a discrete FE model, the existing model will be converted to a discrete FE model during import.
                Do one of the following:
- From the menu bar, select .
 - Press Ctrl + I.
 - In the Import File dialog, navigate to your working directory and select the file to import.
 - If needed, define any options in the Import Options dialog then click Import.
