Remove Cuts Use the Defeature: Cuts tool to extend surface edges and remove cutouts. Note: This feature is not supported for a model with discrete geometry. From the Geometry ribbon, click the Defeature > Cuts tool. Figure 1. Select surface edges with cuts. Remove cuts in the following ways: Remove all selected cuts by clicking Remove All on the guide bar. Remove individual cuts by left-clicking on a selected surface edge.
