Use the Interactive: Biasing tool to apply linear, exponential, or bellcurve biasing to individual edges of a surface, and edit the elements size
distribution.
Use the Interactive: Density tool to edit element density and size along surface
edges.
Before you begin, use the Interactive:
Create tool to define a meshing area by selecting surfaces,
and create an initial mesh.
The local edge element size approximation is based on edge density value and
length. Hence, it can vary slightly for two edges with the same density value.
From the Mesh ribbon, click the Interactive > Density tool.
Optional: On the guide bar, click
to define surface mesh options.
Left-click to select the edge(s) to modify.
In the microdialog, click the icon to switch the value
being defined to either element density or element size.
Edit element density or size in the following ways:
Increase individual edge values by holding Ctrl while left-clicking on an edge; decrease individual edge values by
holding Ctrl while right-clicking on an
edge.
Scroll edge values by holding Ctrl while
scrolling the mouse wheel up and down. Hovering directly over an edge will
only modify that edge; hovering over empty space will modify all selected
edges.
Specify an edge value in the microdialog and
press Enter. If multiple edges are selected, a
common value will be applied. If multiple edges with different edge values
are selected, use the arrows in the microdialog to
modify individual edge values simultaneously, without applying a common
value.
Update
Tip: Clear your selection by left-clicking in empty space.
