Include/Exclude Components From a Section Cut
| Option | Description |
| Include in Section Cuts | Include the selection in a section cut. |
| Exclude from Section Cuts | Exclude the selection from a section cut. The components that are excluded will not be cut through when a section cut is applied (or turned on). This can be useful for investigating models that are surrounded by large domains of mesh (ground, fluid, etc.). For example, in streamline visualization, the model can be excluded from the section cut in order to cut through the fluid only. By default, the streamlines are excluded from section cuts. |
