Version: September 2011 Edition
List of Classification Parameters
- Evaluation Distance
- Reference distance to find the evaluation location from the weld element
at which the stress values are extracted.
- Weld Width
- Width of the weld material from the web wall. This parameter is ignored
if specifying the evaluation distance is done manually.
- Grinding Bonus
- Parameter to specify if the grinding bonus has to be considered or
not.
- Effective Weld Thickness
- This parameter is used to consider the influence of welds which do not
cover the same cross section area as indicated by the shell element in
the respective evaluation location. It modifies the stress at the
evaluation location based on the ratio to the shell thickness. (a >
0)
: Thickness influence represents
the resultant maximum weld thickness. It varies based on the
weld type. this parameter is location specific.
: Indicates which shell thickness
you need for the calculation of effective weld thickness ( a ).
Valid options are t and tmin, also location specific.
t = thickness of welded shell. tmin = min thickness
of all connected shells.
- Mean Stress Sensitivity – Normal
- Mean stress sensitivity factor used for the normal direction
evaluation.
- Mean Stress Sensitivity – Shear
- Mean stress sensitivity factor used for the shear direction
evaluation.
- Notch Class - Transverse Location_X
- Notch class definition considered for the fatigue limit calculation for
the normal stress component in the transverse direction (perpendicular
to the axis of the weld) at ‘X’.
- Notch Class - Longitudinal Location_X:
the normal stress component in the longitudinal direction (parallel to
- Notch Class - Shear Location_X
- Notch class definition considered for the shear stress component at
‘X’.
Note: Where ‘X’ can be any evaluation location.
- Material Yield - Location_X
- Material yield value used for the static evaluation.
Formulation
- Stress Component considered for evaluation
- σT: Transverse component perpendicular to the axis of the
weld
- σL: Longitudinal component parallel to the axis of the
weld
- τ: Shear Component
- Corrected stress calculation
- The stress value correction is carried out using the effective weld
thickness.
- Calculation of the Assessment stress value (numerator in utilization
formulae)
σTA (Stress Amplitude) = (σTmax -
σTmin) / 2The stress amplitude is used as the
numerator for the utilization calculation.
- Fatigue Limit Calculation
The fatigue limit values (σTzul, σLzul, and
τzul), are calculated based on the following regimes of
Stress Ratio ®,
Reference: the DVS1608 regulation document section 7.2.2.
For nominal stress (longitudinal σLzul and transverse
σTzul)
Regime 1:
Regime 2:
Regime 3:
Regime 4:
is the mean stress sensitivity, the
exponent x in the above equations is queried from the below notch detail
tables:
| Curve |
B |
B- |
B+ |
C |
C- |
C+ |
D |
D- |
| x |
6 |
7 |
8 |
9 |
10 |
11 |
12 |
13 |
| Curve |
E1+ |
E1 |
E1- |
E4+ |
E4 |
E4- |
E5+ |
E5 |
E5- |
E6+ |
E6 |
E6- |
| X |
14 |
15 |
16 |
17 |
18 |
19 |
20 |
21 |
22 |
23 |
24 |
25 |
| Curve |
F1+ |
F1 |
F2 |
| x |
26 |
27 |
28 |
For shear stress,
Regime 2:
Regime 3:
Regime 4:
table:
The grinding bonus and the thickness factor is applied to the
calculated fatigue limit for longitudinal and transverse and just the
thickness factor to the calculated shear fatigue limit.
- Utilization Factor Calculation
UT = σTA /
σTzulUL =
σLA /
σLzul
Uτ =
τA / τzul
- Resultant Utilization Calculation
