Editor Settings
Settings to configure the Editor.
Annotations
Displays a summary of all the templex statements in the file at the top of the text area, and displays a templex statement underneath every parameter.
Whitespaces
Displays a black dot for all of the spaces and tabs in the file.
Line numbers
Displays the line number for each line in the file.
Overview and cursor position
Provides an overview of the open file, and displays a range of selection when you select a string of fields in the file.
Column guides
Displays column lines.
