Attach/Detach Parameters from Existing Parameters
  1. From the menu bar, click Tools > Editor.
    The Editor opens.
  2. In the File field, open the file to be used as the base input template.
  3. Attach/detach parameters.
    Option Description
    Attach parameters to existing parameters Highlight the appropriate fields in the text area, then right-click and select Attach to > varname from the context menu.
    Detach parameters from existing parameters Highlight the parameter to detach in text area, then right-click and select Detach > varname from the context menu.
    or
    In the row that contains the parameter to detach, click and select Detach > varname from the context menu.
