Add and Delete Models
In each study, you can add one or more models.
Add Models
Add a model to your study.
  1. In the Define Models step, click Add Model.
  2. In the Add - HyperStudy dialog, define model settings and click OK.
    1. In the Label field, enter a name for the model.
    2. Select a model type.
Tip: Quickly add a model by dragging-and-dropping a supported model file directly into the work area of the Define Models step.
Delete Models
Delete models from your study.
  1. In the Define Models step, select the model in the work area that you wish to delete
  2. Click Remove Model.
