Use the Editor to create and edit template files, parameterize ASCII files, create variables or shape templates, recognize
and edit Templex statements in files, execute parameterized files, and perform advanced editing.
A resource file establishes the basis of the connection to HyperStudy. Information about the input variables and/or output responses are passed through the file.
When defining a model, model resources identify additional files required for the model to evaluate successfully,
for example reference files called by script or linked result files that were generated by other models.
An input variable is a system parameter that influences the system performance in the chosen output response. It is
an object that is varied by the study based on certain rules.
Once the study Setup is complete, an unlimited combination of approaches can be added to a study. A study approach
is a specific set of steps taken to study the mathematical model of a design.
Load Resource Files
Define Model Dependencies
When defining a model, model resources identify additional files required for the model to evaluate successfully, for example reference files called by script or linked result files that were generated by other models.
Specify Solver Input Files
A solver input file is the name of the input file that the model will write during the evaluation.
Select Solver Execution Scripts
Select the solver execution script you would like HyperStudy to use when executing the model.
