Reliability Post Processing
Lookup reliability values.
Lookup Reliability Values
Lookup specific reliability values in the Reliability post processing tab.
  1. From the Post Processing step, click the Reliability tab.
  2. Click Add Reliability.
  3. In the Response column, select an output response.
  4. In the Bound Value column, enter a threshold value for the selected output response.
The percentage of designs that would satisfy the constraint is populated in the Reliability column; this percentage is known as the reliability. The remaining percentage which indicates the probability of failure is populated in the Probability of Failure column.
