UGS_LICENSE_BUNDLE
Specifies the UG license bundle to use for importing UG files.
UGS_LICENSE_BUNDLE value
HyperMesh Environment Variable
Specifies the UG license bundle to use for importing UG files. This is not required when using UG versions prior to NX6.
value
The proper value to point to the license bundle for your system.
Examples
UG license bundle named NXPTNR100: UGS_LICENSE_BUNDLE NXPTNR100.
None.
