Static Ride Analysis
                                             The Static Ride analysis is a simulation of both wheels moving up and down, in phase,         with the steering wheel held
                                                fixed. The chassis is fixed-to-ground. The displacement of the         wheel center is prescribed by the user. The suspension
                                                moves via a simple control system and         a “suspension test rig”. The wheel is constrained at the tire patch location
                                                to the         suspension test rig using an in-plane joint. Standard suspension requests (caster, camber,         toe, etc.)
                                                are included as part of the ride analysis and are described here. The front and         rear suspension ride analyses are
                                                similar.
