| v |
m/s |
Rotation speed of belt surface (be sure to choose rolling_speed = 0 in data
block $sources. Otherwise, the wheel moves away from the belt). |
| number_cleats |
Number of extra cleats on belt (number_cleats = 0
allowed). |
| cleat_height |
mm |
Height of extra cleats. |
| cleat_length |
mm |
Length of cleat, measured in circumferential direction of drum. |
| cleat_bevel_edge_length |
mm |
Length of bevel edge of cleat, measured in circumferential direction of drum.
Bevel edge has 45deg slope. |
| mu_factor_cleat |
Friction modification factor on cleats. |
| acceleration_time |
s |
Optional time span at beginning of simulation during which the belt is
accelerated to nominal speed. |
