Model Check Toolbar
The Model Check toolbar allows you to quickly run the Check Model tool. The types of checks that are conducted are specific to entity types. Check Model detects errors such as negative mass for a body and negative diameter for a beam.
                Figure 1. Model Check Toolbar
