Defining an Expression Output
An expression based output can be used to generate outputs based on solver run time functions. Solvers like MotionSolve and ADAMS provide several functions to track various outputs during the solution process.
View new features for MotionView 2022.
Discover MotionView functionality with interactive tutorials.
MotionView is a general pre-processor for Multi-body Dynamics.
Explore the MotionView menus which provide access to the various wizards, dialogs, tools, and panels.
The Project Browser allows you to view the MotionView model structure while providing display and editing control of entities.
Explore the various panels and tools in MotionView.
The MotionView toolbars provide you with quick access to some of the most commonly used panels and tools.
The Entity Selector
allows you to set the graphic screen selection mode.
Model files are composed of many different parts, or entities. MotionView allows you to change the display attributes of each entity in a graphic. Visual properties such as shading, color, and mesh lines can be assigned using the Graphic Entity Attributes panel.
The Run Solver tool allows you to either run the current model or run an existing solver command file generated previously by MotionView.
The System/Assembly panel allows you to add new systems and assemblies to your model, modify attachments, and set initial conditions and options for systems and assemblies.
The Analysis panel allows you to add new analyses to your model, modify attachments, set initial conditions for analyses, and set analyses options.
The Command Sets panel allows you to create command sets for the solver-command file. The command sets for a model are order dependent, since they define the contents of the solver command file.
The Points tool allows you to add points to models and edit point coordinates.
Use the Vectors tool to create and edit vectors.
Use the Markers tool to create coordinate systems and reference frames.
Coordinate systems in MotionView can be oriented using a variety of methods.
Use the Curves tool to create and edit curves.
Use the Deformable Curves tool to create and edit deformable curves.
The Spline3D panel allows you to add and edit three dimensional spline data.
The Surfaces tool allows you to create surfaces for use with advanced joint entities.
Use the Deformable Surfaces tool to create and edit deformable surfaces. These entities can change shape during the simulation and can be used with advanced joints and contacts.
Use the Graphics tool to create and edit visualizations for entities during pre-processing and post-processing.
Use the Bodies tool to create and edit rigid, point mass, and deformable/flexible bodies.
Use the Joints tool to create and edit basic joints.
Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two bodies.
A Coupler entity defines an algebraic relationship between the degrees of freedom of two or three joints.
Use the Gears tool to create a gear entity to relate the motion of two joints.
Use the Bushings tool to create bushings and edit their connectivity, properties, and orientation rules.
Use the General Constraints tool to create a generic expression based constraint.
Use the Fields tool to create a compliant connection between two bodies where stiffness or damping in one direction can be a function of displacement in another direction
Use the Spring Dampers tool to edit the connectivity, properties, and initial conditions of springs and dampers.
Use the Beams to create beams and edit their connectivity, properties, and orientations.
Use the PolyBeams tool to create polybeams and edit their points and properties.
Use the Motions tool to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints.
Use the Forces tool to create forces and to edit the orientation and properties of forces.
The Modal Forces tool allows you to include a disturbed force on a flexible body that exists in the modal form in the flexible body H3D.
Use the Contacts tool to specify the attributes of a contact force between two bodies.
Use the Outputs tool to create a result output request to the solver, which writes out the requested data for plotting data.
The main types of outputs that can be defined using output requests are displacement, velocity, acceleration, and force. In addition to these, more complex outputs can be extracted using the Expressions and User-defined output types. The output request plays a very important role in post processing the results from a solver run. Output requests also pave the way for signal processing of data that is generated by a multi-body simulation.
In this case, the output is generated with respect to a selected entity
Using this method, the output can be measured for all entities of a certain type that are currently present in the model.
Through this method, a displacement , velocity, or acceleration between two bodies can be measured relative to each other.
Define the output using the User-Defined tab which will allow you to specify the properties of the output using user subroutines.
Use the Sensors tool to sense an event during simulation and to define a response to that event
Use the State Equations tool to create and set control state equation data.
Use the FMU tool to add a Functional Mock-up Unit and connect it to a multi-body model.
Use the Templates tool to create and edit blocks of text that contain data fields and programming instructions.
Use the Forms tool to edit general data entry forms.
Use the DataSets tool to create and edit datasets comprised of object types, such as real, string, boolean, integer, and options.
Use the Variables tool to create solver variables that can be used to create an algebraic expression of state variables, as well as other solver variables. This can then be referenced in function expressions throughout the solver input file.
Use the Arrays tool to create solver arrays and set solver array data. Solver array types include X array, Y array, U array, IC array, Plant Input array, and Plant Output array.
Use the Strings tool to create a solver string and set solver string data. A solver string provides a string that can be accessed within the model, for example, to pass into a user subroutine.
Use the SISOs tool to set control SISO data. This data can be used to add additional states to the mechanical system being modeled.
Use the Diff Equations tool to set solver differential equations. These equations can be used to add additional states to the mechanical system being modeled.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
Solvers and translators supported in MotionView.
Discover optimization with MotionView, MotionSolve, and HyperStudy.
MotionView supports a limited version of interface with HyperWorks Collaboration Tools.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
MotionView help for HyperWorks.
Use MotionView entity data members to maintain a parametric relation with the entity and the output being measured.
For example, the
expression`DX({b_ball.cm.id}) uses the
id of the user specified CM marker (implicit marker
created by MotionView at a user given cg
point) of the body b_ball.
