Defining an Expression Output
An expression based output can be used to generate outputs based on solver run time functions. Solvers like MotionSolve and ADAMS provide several functions to track various outputs during the solution process.
View new features for MotionView 2022.
Discover MotionView functionality with interactive tutorials.
MotionView is a general pre-processor for Multi-body Dynamics.
Explore the MotionView menus which provide access to the various wizards, dialogs, tools, and panels.
The Project Browser allows you to view the MotionView model structure while providing display and editing control of entities.
Explore the various panels and tools in MotionView.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
Solvers and translators supported in MotionView.
Create and edit outputs, add an analysis using the task wizard, check the model, and run the solver.
Use the Outputs tool to create a result output request to the solver, which writes out the requested data for plotting data.
The main types of outputs that can be defined using output requests are displacement, velocity, acceleration, and force. In addition to these, more complex outputs can be extracted using the Expressions and User-defined output types. The output request plays a very important role in post processing the results from a solver run. Output requests also pave the way for signal processing of data that is generated by a multi-body simulation.
In this case, the output is generated with respect to a selected entity
Using this method, the output can be measured for all entities of a certain type that are currently present in the model.
Through this method, a displacement , velocity, or acceleration between two bodies can be measured relative to each other.
Define the output using the User-Defined tab which will allow you to specify the properties of the output using user subroutines.
Use the Check tool to search for any missing references in defined entities or errors in properties.
The Run Solver tool allows you to save and run the current model.
Use the Reports tool to view the report definitions of associated analysis tasks.
Discover optimization with MotionView, MotionSolve, and HyperStudy.
Use the FMU tool to add a Functional Mock-up Unit and connect it to a multi-body model.
MotionView supports a limited version of interface with HyperWorks Collaboration Tools.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
MotionView help for HyperWorks.
Use MotionView entity data members to maintain a parametric relation with the entity and the output being measured.
For example, the
expression`DX({b_ball.cm.id}) uses the
id of the user specified CM marker (implicit marker
created by MotionView at a user given cg
point) of the body b_ball.
