The rotating flatbelt testrig is implemented as a 2D road type. If the ROAD_TYPE is set to
flatbelt, COSIN/road searches and reads the following data items in the [PARAMETERS]
section:
| Name of input variable |
Unit |
Meaning |
| number_cleats |
Number of extra cleats on belt (number_cleats = 0
allowed) |
| cleat_direction |
angle |
Direction of cleat relative to belt lateral direction. Direction is zero if
cleat is oriented exactly in transversal direction. Direction angle is measured
counter-clockwise if looking from above onto the belt surface. Default value is
0 (transversal cleat).
| mu_factor_cleat |
Friction modification factor on cleats. |
The flatbelt speed is defined by one of the following alternatives:
Either:
| v |
| v |
length/time |
Constant rotation speed of drum surface. |
| acceleration_time |
time |
Time span at beginning of dynamic simulation, to accelerate belt from
stand-still to nominal velocity. Default value is 0.
Or:
| data sub-section (TV_DATA) |
Arbitrarily many lines with 2 values of type: time, length/time |
Data pairs defining speed-vs.-time data of the belt’s time-dependent surface
speed profile. t values (first value in each line) should be in ascending
order.
The exact geometry of the cleat is defined by one of the three following alternatives:
Either:
| cleat_height |
length |
Height of cleats. |
| cleat_length |
length |
Length of cleat, measured in circumferential direction of belt. |
| cleat_bevel_edge_length |
length |
Length of bevel edge of cleat, measured in circumferential direction of belt.
Bevel edge has 45 degree slope. |
| cleat_edge_rounded |
- 0
- Cleat bevel edge is flat.
- 1
- Cleat bevel edge is rounded by a quarter circle.
Or:
| data sub-section (XZR_DATA) |
Arbitrarily many lines with data of type: 3 x length |
Data triples defining x and z data of the cross section of the cleat,
together with rounding radii in these data points. Rounding radii may be zero. x
values should be in ascending order. First and last y value should be
zero. |
Optionally, the exact height geometry of the stoppers can be specified by spline
data:
| data sub-section (stopper_geometry) |
Arbitrarily many lines with data of type: 2 x length |
Data pairs defining x and z data of the stoppers. x values must be
non-negative and ascending: x = 0 refers to the start in longitudinal direction of
the stopper. |
