An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies
the assembly definition for a particular loadcase simulation event.
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be
used in setting up Panel Participation diagnostic output in NVH analysis.
Set up the simulation model, materials, domains and boundaries.
Analysis Manager
An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies the assembly definition for a particular loadcase simulation event.
Batch Model Check Run
Reduce the amount of manual work involved in performing a normal modes run to check out multiple modules by batch processing.
Batch Model Reduction
Reduce the amount of manual work involved in generating CMS superelements or CDS superelements for multiple modules by batch processing.
Job Manager
Job Manager is designed to provide a way to interact with analysis jobs created through the NVH Director.
Tuning Set Manager
Create standard tuning sets that can be used in the Analysis Manager for automatically setting up quick modification runs in NVH analysis.
Response Point Manager
Create defined response points that will be automatically used in setting up output requests in NVH analysis.
Frequency Set Manager
Create standard analysis frequency sets that will be automatically used in setting up analysis frequencies in NVH analysis.
Control Volume Manager
Create defined control volumes that will be automatically used in setting up Transfer Path Analysis diagnostic output in NVH analysis.
Panel Set Manager
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be used in setting up Panel Participation diagnostic output in NVH analysis.
