Set parent modules with CMS SE representation in H3D format to be used for analysis in lieu of child module representations
when rolled up, or use the child representations when rolled down.
To manage any of the modules shown in the Assembly Browser, right-click on a module and select Edit Representations. This opens the Edit Module tab, and the Representation sub-tab is shown.
Assembly Browser
The Assembly Browser is an object-oriented modeling environment where the fundamental entity is the module entity.
Module Symmetry
Allows symmetric creation of LP Modules, Connections and dynamic LCS.
Module Reparenting
Allows you to change the assembly hierarchy by cutting or pasting the modules.
Module Roll-Up/Roll-Down
Set parent modules with CMS SE representation in H3D format to be used for analysis in lieu of child module representations when rolled up, or use the child representations when rolled down.
Module Subsystem
Select and define a set of modules as the subsystem used for analysis.
Edit Module
Batch Create Assembly
Create a complete vehicle assembly using external .csv files for assembly, tagpoints, connections, isolator, network diagram, symmetry and analysis.
Batch Create Module
Create assembly hierarchy and assign ID ranges to the modules from external .csv files.
Tagpoint Mapping Tool
Allows automated mapping/creation of tagpoints and connections between data from different sources.
Connection Creation
Connections can be created using the Create Connection-Interactive and Create Connection-Automatic tools.
Connection Browser
Once the connections have been created, use the Connector Browser to review the connections.
Connection Manager
Connections can be managed by right-clicking on a connector in the Connector Browser and selecting Edit Connection.
Connection Realization
Use the Connection Realization tool for realization of selected connections based on the specified Tolerance, Property state and State rule.
LCS Manager
Allows you to manage local coordinate systems created in the Assembly framework.
Network View
The network view is a block diagram view emphasizing inter-connectivity of the assembly.
